- Dec 25, 2011
- 10,513
Unfortunately, as far as I have found, we have no copies of original drawings for any 6" parts. But the countershaft spindle bushings are undoubtedly commercial parts, probably Oilite. I would call Clausing (armed with the part numbers) and check whether they have the spindle and bushings. If they do, either buy them or don't. If they don't have them, ask for a copy of the drawings. The bushing drawing should have the Oilite part number on it. You should be able to buy the bushings and buy a piece of steel shaft material that all you have to do to is cut to length and slightly bevel the ends. However, I would suggest milling slight flats for the pulley set screws to seat on.
The bushings are pressed in. To remove, you need a receiver with an ID slightly larger than the bushing OD and a length slightly longer than the bushing. And you need a shouldered pusher just slightly (maybe 0.010") smaller in diameter than the bushing and a little longer. On one end, turn down about 1/4" of the length to about 0.005" smaller than the bushing ID. Then use a press to remove the bushings.
I would suggest after installing the new bushings that it would be a good idea to drill a 1/8" diameter hole through the hanger and one side of the bushing. Locate it so that it is accessible from the front of the machine. Use the same oil can as has the special tip for the spring-loaded ball type oilers. Otherwise, most of the oil you squirt on the shaft and bushing is just going to sling off. I don't know why Atlas didn't make some provision for this. Maybe they believed the Oilite advertising.
If the 2-step countershaft pulley bore is in fact worn, I would recommend having it bushed and bored to fit the original spindle diameter. Then run a tap drill and 1/4"-20 tap through through the existing threaded hole and through the bushing. If you up the spindle diameter, you'll have to deal with the larger bushings required which will mean boring the 4-step pulley, hanger casting, and collars.
Addenda: According to the parts manuals, all of the countershaft parts except for the bracket casting and hanger casting are the same as on the 618.
