- Feb 26, 2014
- 171
I came across an 8540 horizontal milling machine on Craig's list that was what I thought a pretty good deal. So I bought it and moved it to the basement.
My questions are related to milling steel. When I got it set up I played around with it using scrap aluminum and even some wood. After I was comfortable with the controls and felt that I had everything set up right, I tried milling a piece of steel. I don't have a pic of the steel but it leaves a beautiful finish on aluminum.
I'm guessing it's an rpm issue with the cutter (too slow) but it just seems that trying to cut steel is a bad idea.
I'm using a 4 1/2" diameter side cutting wheel. I'd guess I'd call it chatter even trying to take the lightest of cuts. Not sure if this make sense.
Any enlightenment would be great!
Thank you.
