- Aug 4, 2015
- 291
I was trying to think up a way to have a mounting plate that I would be changing fixtures on often and I was trying to figure out how those fixtures could be positioned accurately as they were removed and replaced without needing to align them each time only to bolt them down. Thought was that If I made up bolts that the top of the bolt was tapered and screwed down into a tapered hole on the fixture the taper would square the fixture up without needing to install alignment pins that may effect the placement of other fixtures. Any thoughts on the tapered bolt idea. It seems like a viable solution. I was also figuring that if a set of guide tapers were created to guide drills into the mount plate, it would allow the fixture to be placed once and the holes drilled and tapped. Thoughts?
