I currently have a 1/2 HP motor, though if I go to a VFD I'll likely go to a 3/4 HP, though not any larger as I have to replace the motor with a 3-phase unit, anyway.
I think I'll pursue your recommendation and calculate the RPMs with the current pulley arrangment. Appreciate the thought, I hadn't thought of doing that.
Measure the diameters of pulleys and do some math...
That motor pulley looks to be very large.
The spindle should be ball or roller bearing so it should be fine but other bearings not so confirm your rpm is within reasonable range.
The motor may bounce more or struggle with heavy cuts as well.
Check hp of motor too as a too high power with too high rpm is a bit risky...The lathe may break upon operator error instead of slipping or stalling.
