- Dec 25, 2011
- 10,511
(1) No.
(2) It probably won't hurt to drill the holes. One other member here reported that after drilling holes, the operating temperature dropped from hot after a few minutes to not much above ambient. I can only assume that the bushings that he used were sintered bronze and not brass. You will, however, have to fill the cups more frequently. If you decide to drill the holes, drill them before you run the reamer through. After the first three or four oilings, you might put a low density felt plug in the oil cups to retard the oil drainage rate.
