- Sep 25, 2012
- 302
I do a lot of drilling into barrels using this v block set up on top of parallels in my vise. I noticed that when I tighten the vise the parallels become slightly loose. Normally I would attribute this to a unsquare part if only one parallel was loose but I’m positive my v block is square and both parallels are loose the same exact amount. Second I am using a Kurt Angloc vise. Shouldn’t that push the v block down onto the parallels? Should I tighten the sphere set screw up more on the vise? Im not sure if I have it adjusted right. Thanks.
