- Jul 11, 2017
- 41
When I bought my lathe years ago it had a composition belt of some kind with alligator clips. At a certain point it gave up the ghost and I got a belt from McMaster Carr called a "high speed extended life leather belt" that had a nylon core to reduce stretch. I had no idea what I was doing and made a scarf joint in it and glued it together with Weldwood contact cement. It actually worked for a few years of intermittent use. Finally the glue joint gave up and refused to be re-made.
So I thought I'd try a real leather belt. I had some leather from Tandy that measures about 0.15" thick and I watched a youtube video by ghostses from back in 2012 about lacing the belt. So that's what I did and made a very pretty job of it.
Now the problem is that it doesn't transmit very much power at all. It slips. I can get the thing going by turning the 3-jaw by hand but it has no power. Admittedly I still don't really know what I'm doing. Is there a particular kind of leather I have to use? Is it just a matter of tension? Do I need belt dressing? I have the flesh side of the leather outermost. The smooth side is against the wheels.
I'd like to make the leather work. I could go back to the high-speed stuff and lace it like I did the plain leather. I don't want to use a serpentine or alligator clips.
