- Feb 1, 2015
- 9,621
I added decoupling capacitors inside my Arduino box and they decreased the number if glitches but didn't entirely eliminate them. I also tried ferrite chocks on the power supply cable for the Arduino and on the lathe motor cord. Also tried was using a different mains circuit. My cables from the scale pickups run through flexible stainless steel conduit, grounded at both ends due to the mounting. There is about 4" of exposed cable at either end.
I should say that the Arduino circuit was breadboarded on perf board using one of the Arduino shield prototypong boards and mounted in a Bakelite box so it is not the neatest design regarding suppression of interference.
With the decoupling capacitors added to the scale pickups, I haven't seen any glitches. However, the ionsidious nater of intermittants is just when you think you solved the problem, they show up. Time will tell. Fingers crossed.
