- Feb 1, 2015
- 9,623
When looking for a suitable candidate for a transformer, I would want one with power rating of 1 kva or more. This would be equivalent of an input current rating of around 10 amps. A lower rated transformer wouldn't have sufficient iron in the core and and the flux would saturate. In addition to a microwave transformer, a large battery charger transformer might work well. I have one with a 25 amp intermittent rating, so good for 3 kva in a low duty cycle mode. A spot welder is tupocally low duty cycle so it would be a good match. A thrirf possibility is a Variac. Replacement brushes are insanely expensive and many of the old Variacs are just scrapped. A 2 kva Variac should work well. The toroidal construction makes adding a high current secondary winding simple. Just strip off all the hardware and add the cable winding.
As to using MIG tips for the contacts, they will probably not work well. They have too much resistance for the amount of current required and would heat up excessively, causing distortion of the tip. You can buy spot welding tips on Amazon.
