- Dec 27, 2014
- 4,058
Could you insert a spacer under the cap of the handle to change it's "lock" position?The handle does not index so it tends to end up over the stock
It really sounds to me like the pistons are switched to the wrong hole. Both pistons ride on the same cam but are offset by 90 deg. For both pistons to lock with the handle always ending up in the same position, the pistons have to be a different length.Yes. I thought I might tear into that as an option and I might do that even if I get a new one. But, there are a couple of other problems with it. The handle does not index so it tends to end up over the stock or in an awkward position when tightened. I might be able to fix that too, not sure. Griz. says "that's the way it is designed". The third thing is that the position of the holder when semi-snug and fully snugged changes quite a lot. I'm hoping a wedge type might help improve that too. Not sure who's QCTP they use but I want to avoid that one. I'll be looking at the Phase II's more closely. Really I would rather buy other tooling with the savings if a Phase II works well.
I've had to solve that problem a couple times with QCTPs. Nowadays I routinely add extra handle holes at 90º intervals (see post #6 in https://www.hobby-machinist.com/threads/phase-2-qctp-adjustments-modifications.30523/#post-262027 ). Then screw the handle into whatever hole is appropriate.Yes. I thought I might tear into that as an option and I might do that even if I get a new one. But, there are a couple of other problems with it. The handle does not index so it tends to end up over the stock or in an awkward position when tightened. I might be able to fix that too, not sure.
Not sure I understand what's moving. If it's the position of the tool holder on the "head," the wedge type will definitely do better for you. It also sounds like the dovetails on your QCTP are a bit loosy-goosy. And a new, decent quality QCTP will solve that for you.The third thing is that the position of the holder when semi-snug and fully snugged changes quite a lot. I'm hoping a wedge type might help improve that too. Not sure who's QCTP they use but I want to avoid that one. I'll be looking at the Phase II's more closely. Really I would rather buy other tooling with the savings if a Phase II works well.
I had considered the Dorian Quadra (at the time there was a new one listed on eBay at 1/2 price), but at the end of the Day they all do the same thing, and although indexing is a nice you just loosen the nut and turn the tool post to whatever desired position. The Dorian Quadra style (and also Aloris indexing) allows multiple holders to be mounted at the same time using their proprietary "expensive" holders. Not something I see needed nor fiscally sound, unless you have money to burn. The Dorian indexing using ball indents, I have seen a few where under high torque they twisted, also one where the post broke. The Aloris uses indexing pins. The standard Dorian uses two dowel pins to align the QCTP, but I do not use them.
I check prices, this would be my suggestion for CXA, the Dorian at $494. Aloris also has a July sale 10% off, but ends up being $564.
Aloris:
