- Oct 17, 2018
- 925
PROBLEM
I'm assembling a QCGB for my 12" and it all has gone together quite well, except there appears to be something binding when I turn the gears. I can turn them all the way, but at one point it gets very hard to turn them by hand, then they release and get smooth, then release, etc... There don't appear to be and burrs or edges catching on anything.
MY THOUGHTS
1. I have not tightened any of the set screws. Could that be the problem?
2. Are the gears meshing properly? They all seem to, but maybe I've got some in the wrong place?
3. I have light lube on the shafts. Do I need any on the gears for testing purposes? I will of course lube these before running them under power.
4. There are newer gears (the ones on the far right of both shafts). Could these not be "broken in"?
5. Burrs/dents/imperfections on the gear teeth? I don't see any, and filed a few seemingly minor ones down.
Here is a photo of the assembly. I used the parts diagram in the MOLO as a guide:
Here are some other reference photos:
If anyone sees any glaring errors, please let me know. I'd like to make sure this will run smoothly before I use power to turn it.
MY THOUGHTS
