Q re: 3/8 x 27 die
auto.pilot
Mar 5, 2012
161
I am attempting to make some parts for an old Craftsman scroll saw. In a couple of spots, the threads are 3/8 x 27 tpi (not 24). I have a die in this size, but it is tapered for pipe threads and won't work. No local store carries a die in this size, so I am force to purchase on-line. The link below appears to be what I need and is marked 'special thread'. Is this the correct die for these old threads (50's era?)
http://www.amazon.com/Special-Threa...TF8&qid=1340586655&sr=1-5&keywords=3/8+27+die
Thanks. Jim
The "special thread" just refers to the fact that it's not a standard pitch size. Here's a good description of the types of dies:
http://www.icscuttingtools.com/Dies.htm
So if you're certain that its 27 tpi you want, that die will cut it. And since it's adjustable you can tweak the diameter a bit over/under if need be.
And that price on Amazon seems pretty good - the same die on MSC is closer to $22.
I learn something new everyday. I didn't think it was possible to get a die in that oddball tpi. :thinking:
Sometimes seen in the threads mounting switches.
The story is that when houses 1st went electric they were already plumbed with 1/4" pipe so 3/8 x 27 was used to make fixtures compatible and it has stuck around as defacto lamp part thread.
Steve
I was going by memory but now that you mention it I think you are right.
Steve
I use 1/8" 27 bspp all the time and it is afull close to 3/8.
Steve
Actually, lamp threaded stock is 1/8-27 NPS and will measure around .388 or so--not a real precision part.
Regards
Bob
