    Dismiss Notice
Protecting My Micrometer...
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by Dirty Al, Oct 3, 2016.
  1. Dirty Al
    Dirty Al Iron Registered Member
    4
    3
    City:
    Portland
    State:
    Oregon
    -Return to Top-
    I've got a micrometer I don't use often (A Central Tools 2 - 3" micrometer) so I'd like to put it away properly so it will be protected and ready for use. So should I get some desiccant ( a bag of 'Do Not Eat!") and seal it in a freezer bag or what? My shop and office aren't particularly humid but sometimes things happen, even in the best families!
  2. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,548
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    A desiccant along with keeping out moisture works, as does VPI paper. Coating tools with a stable oil with anti corrosion additives like ATF also works for tools in more general use. I live in Sacramento, California, and it is essentially an irrigated sub-desert, so I definitely have it easier than most of us, and some of my methods may not work as well in humid and/or coastal areas. Keeping tool storage areas at a temperature well above the dew point (or lowering the dew point by keeping the relative humidity lower) is a basic of fighting corrosion...
  3. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,187
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Get you a bottle of Starrett M-1 oil. Or get the airesol can of M-1 oil and use on your tools. I keep a case of it on hand as much of it as I use for just about everything. Little Machine Shop sells it and usually has the best price for it that I've found. Ken
  4. Uglydog
    Uglydog United States Active User H-M Supporter-Premium
    1,095
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    I run two sets of outside mics.
    One set is at my surface plate. I use them exclusively for inspection in that area. I work at wiping them down after each use.
    The other set I drag around the shop. This second set is potentially subjected to a lot of abuse including accidentally dropping.
    This second set is a mix of what ever I could find a hot price on. While I try to take care of them. I don't go nuts.
    I heat my shop to at least 55degrees F year round.
    Because I don't run AC in the summer, my biggest problem seems to be my own salty sweat. It leaves permanent fingerprints and rust.
    Even skin oils in the absence of sweat seems to leave a mark.
    I'm going to check into this M1 oil!
    Daryl
    MN
  5. T Bredehoft
    T Bredehoft Active User H-M Supporter-Premium
    1,241
    113
    Central Ohio
    City:
    St. Louisville
    State:
    Ohio
    -Return to Top-
    I veto Starett M-1 oil, I put some on some Jo blocks, in a year they were stained brown and would not wring.
  6. 4gsr
    2,187
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Never had that problem using it on J-blocks... WD-40 yes!!
    EDIT: Use the Tool & Instrument oil. Here's a listing for it.
    http://www.littlemachineshop.com/products/product_view.php?ProductID=1825&category=2122081962
    Tom, my apology. I thought the two oils were the same. They are not the same product.
    I still stand on using M-1 over WD-40 any day in my shop.
    Ken
  7. JPMacG
    JPMacG Active User H-M Supporter-Premium
    77
    28
    City:
    Ivyland
    State:
    Pennsylvania
    -Return to Top-
    Dehumidifier set to 55% seems to do it for me. Of course, it is not free. It costs about $40 per month in electricity to run.
  8. Dirty Al
    4
    3
    City:
    Portland
    State:
    Oregon
    -Return to Top-
    Thanks to all for the great replies!
    I'm going to look into the M-1 oil and VPI paper...
    Al
  9. Fabrickator
    Fabrickator United States Active User Active Member
    340
    63
    City:
    Lakewood
    State:
    California
    -Return to Top-
    I use a light oil like WD 40 to wipe them down and I keep them in their protective boxes/sleeves or whatever they came in. I've had to make a couple of boxes as well for some "homeless" tools I've picked up. I keep all of my calipers, rules, squares and such with no protection in a special drawer with a felt liner and a dozen scattered desiccant bags. Most all of my mics were purchased in the 80's and they still look new.
    But I live in SoCal. I'm sure you have to be extra diligent in high moisture or humid environments.
  10. Doubleeboy
    Doubleeboy Active User Active Member
    253
    63
    City:
    Eugene
    State:
    Oregon
    -Return to Top-
    If you absolutely, positively must have your tools rust, coat them with WD40 and then forget them, come back months later and enjoy that beautiful patina of red/brown. Instrument oil for instruments and M1 for everything else. This has worked for me for years.
    michael
    Nogoingback and 4gsr like this.
  11. kd4gij
    kd4gij United States Active User Active Member
    1,125
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    I use break free CLP it has kept my firearms and tools rust free for years on the west coast of FL were humidity is 80 to 90% most of the year.
    4gsr likes this.
  12. EmilioG
    EmilioG United States Active User H-M Supporter-Premium
    294
    63
    City:
    HUNTINGTON
    State:
    New York
    -Return to Top-
    T-9 BoeShield, Starrett Tool oil and Dow Corning Molykote Metal Protector and Vci paper work for me.
    The DC Metal Protector is great because it;s a thin wax film, wax in solvent. All oils will dissipate after a while and you will get rust., or worse.
    Investing in a dehumidifier is a good safe bet too.
    Bob Korves likes this.
Share This Page
