I have a lot of brass stock. Flat and round. It is available to me and machines easily. I see many shop projects that use steel for things like indicator bases, chip holders, stops, clamps, rods, etc.
I know brass work hardens very easily, so I would avoid using it in a flexible area, such as for a clamp of some sort. And I realize it is softer than steel so it will dent and ding easily. So anything that is dimensionally critical is out, also I think it is more susceptible to temperature variation that steel. (is this true?)
Is there any reason I should not consider brass for some tool making projects or for jig or fixture uses?
For example, consider a vise stop for the milling machine. The type that bolts onto the vise. Is there any reason I should not use brass for this project?
