I got myself into a pickle....
The single phase, 115V 1 HP motor powering my South Bend 9A needed a new shaft bearing. It also became apparent the drum switch needed replacement. So I procured a Dayton 2X440A drum switch while the motor was being repaired.
I am now trying to put the system back together and have a small problem. I can't figure out which terminals on the drum switch to wire into the cable coming from the motor and out to the wall plug. (The instructions inside the switch cover are incomprehensible to me).
As shown on the attached graphic, which drum switch terminals (1-6) are the leads (A,B, C, D) wired to?
