I'm making a part to affix to my lathe's spindle, and I'll be cutting an internal thread of 1.5"-8. In the past when I've cut these threads its been on a part where the thread was completely through the part. This time I'll need to put in a relief cut so I can move the cross slide when the tool clears the thread. I've not made a tool to accomplish this particular task before, and I'm a little fuzzy on the most appropriate shape. I've got a 5/8" boring bar with the 1/4" slots for HSS tool bits, and I am able to grind my tools, with varying degrees of success so far.
The other aspect is, should I be just doing a plunge cut into the ID or should I be trying to make short passes. All blind work, of course, so I'm a little leary about jumping right in.
I'm making a collet holder that will attach directly to the spindle so I can put the work through the collets and subsequently through the spindle. The tool I have now doesn't allow me to do more than hold the work.
I've got a piece of crs that I'm using to make this piece, and I've got the ID bored to the min diameter of the thread now. I just need to get the relief cut made before I proceed any further with it.
Opinions from persons more experienced than I would be appreciated. Thank you.
Terry
Terry
