- Apr 23, 2018
- 6,560
Sounds good, I'll clean you out if you're not planning to use them.
See, I thought you sold off those insert holders- I remember this from... uh, somewhere on this site. Yeah, PM me your price.Quick pic . Used them on my 17" Leblond which is gone . Have a Dorian BXA on the 14" Republic , so all these can go to make room . Off to work soon .
FWIW . We had a 20" Nardini down at the paper plant along with a 17" Colchester . The Nardini never got used and was in PERFECT condition . Don't know where it went when they closed the doors .
Love the names! Just hope neither detonates in the shop!I'll skip ahead a bit, because right at this point my big RPC arrived!
You may think that by having it on a dolly and in my driveway was good enough... This big ol' pig kicked my butt up the steps and across the yard.
The WEG motor on the Nardini has a 5 hp wind and an 8 hp wind. I had to buy a 20 hp rotary power converter to start that motor, apparently the Brazilian AC motors have high inductance. That means #6 wire and an 80-amp breaker.
Everything done up nice:
View attachment 444177View attachment 444175
I haven't been able to get away from EU appliances. I'll have to wait for that Bosch and Karcher stuff to wear out. Might take a while, so I'll add some 15 amp Schucko outlets (overdriven at 60 hz, but the motors don't care). This configuration is legally NEC exempt if you follow the wires.
I installed interphase volt/amp meters. They have a fast enough response rate to be useful. I also gave the 20 hp RPC an appropriate name tag:
And provided my 5 hp RPC with a similar name tag while I was at it!View attachment 444173:
