- Apr 21, 2015
- 591
I've never used it, but maybe 410 stainless? Obviously not 300 series since it's magnetic.
I decided to cold blue my fly cutter. I dropped it into a cup of oxpho-blue with giddy excitement and anxiously awaited the chemical reaction. I've had great success with this stuff in another project and really liked the way that turned out.
10, 20, 30 seconds go by and nothing was happening. This is used bluing that I had rebottled. I thought to myself maybe it has gone bad or inert or something. I test a piece of known cold rolled and it blackened almost instantly.
It appears I unknowingly made this fly cutter out of what I assume is stainless steel of some variety. I find this kind of funny because I was nervous about working with stainless steel. I understand it can be more difficult to machine. This is also means I have a 2" round over a foot long of stainless stock, which is good to know.
1/4 -20 x 3/8. I bought one of those set screw assortments on Scamazon and that size just fit the piece well.I really enjoyed this post. I want to make one of these now! What size set screws did you drill and tap for?
I'm no expert and suspect it doesn't make a huge difference, but somebody once told me to use fine threads for things like tool and work holding whenever possible (1/4-28 vs 1/4-20). More secure and finer adjustment.
All the threads are engaged on this setup for the length of the 3/8 set screw. They snug up real nice and give that satisfying SNAP when you pop them loose. But good information though, thank you. I'll keep that in mind for future projects.The minor diameter is larger on fine-thread screws, which is somewhat stronger than the coarse-thread.
True. But I looked it up and there is only a 0.0175”difference in minor diameter between 1/4-20 UNC and 1/4-28 UNF.The minor diameter is larger on fine-thread screws
