- Oct 18, 2016
- 2,872
DONE:
I decided to take the advice on polishing. Taking my time, I slid the jaw into the bore and looked for the worn spots when it was pulled out. I started with 400 grit emery paper and finished with 1500,
which gave a better surface finish than the parts had when received. I just kept working at it a little at a time, until the jaw slid in normally. I really didn't take much material off: the jaws are pretty
hard, and when I measured it had barely changed from measurement taken last week. Assembled it with some chuck grease, it works just fine.
I did go back and measure the parts that came out when I took it apart. They measured up exactly the same as the #1 and #3 jaws. I think that #2 jaw was a bit out of tolerance from Jacobs,
but it's all good now.
Thanks to everyone for your suggestions.
so at .oo05" I would polish the bad jaw until it just fits might only take .00025 to get it to fit and at that number runout will be minimal at best. at least you will have a chuck to use with no additional cost. you might have got a hole at the very least of its tolerance and a jaw at the very most of its could happen. I repeat polish it until it just fits bill
]Sometimes, the jaw will go in if turned 90 degrees from normal and go in. If you can get it to do just that, twist the jaw several times to get a dull spot in the ID of the chuck body. This would indicate positive metal that needs to be removed. Now it the jaw will not go at all turned 90 degree, then it could be the jaw. I have polished the jaws too to get them to go in.
