- Mar 20, 2014
- 418
Posting this as it may be of use to someone else.
I recently got a 25-50mm digit mic on eBay, and whilst it came with its original Mitutoyo box, there was no foam insert with it. So I knocked this up to slip inside the box to keep the mic from rattling around. I suppose it would probably fit the inch version (1-2”) of the mic as well with no real fit issues... and it may fit other brand mics of similar dimensions.
STL file is here on thingiverse:
25-50mm Micrometer Tray by GreatOldOne
This is an insert tray for a Mitutoyo 25-50mm Digit micrometer. It is designed to specifically fit the case that my mic came with, which had no foam insert when I purchased it off eBay. It may fit other similar sized micrometers, but you will have to measure and see. Fusion 360 files...
www.thingiverse.com
