- Nov 27, 2012
- 7,863
Yes, I hold the spindle with the tool provided. Then just snug the drill chuck with the other spanner that hooks to the drill chuck. If your drill should spin and not hold tight you can bugger up the shank of the drill. Sometimes if I am just spotting somthing soft with a center drill I just hand tighten then install drill and give it a snug. Figured that was the way its meant to be done because of the tools provided.
Yup, like Mike said, you don't need to use the spanner to tighten the chuck, it's meant for loosening. Not good practice IMO. Keyless chucks are designed to self tighten, they get tighter as more torque is applied to the jaws by the drill bit. This can be a nuisance sometimes. I've had my keyless chuck in the lathe self tighten so hard that I had one heck of a time getting it loose with the spanner, jaws indented the drill bit shank also. Never again will I use S&D drills in a keyless chuck, I've been trying to avoid using them altogether anyway.
I originally bought a Glacern integral shank keyless chuck for mill use cause it's shorter. But the integral chuck doesn't have a fixed collar to grip for tightening. Eventually I got sick of reaching up to use the spindle stop or putting in low gear to tighten the chuck (by hand). I switched to the normal style that has the fixed collar. The added stick out doesn't bother me at all which I originally thought it would. I love this one so much better, much quicker to snug down. Which reminds me, I need to dig that integral chuck out of hiding & sell it.
