- Jan 6, 2017
- 1,235
QFT! Planning is the first element to success, and drawings are the first step in planning a machining project. The mere act of committing the plan to CAD can be tremendously helpful in figuring out your order of operations as well as tooling.Good drawings make good parts!
GsT
V26 will (should) be out in a out a month. It has a lot of updates to the 2d drawing module, as well as a major update converting all of the UI graphics in the ribbon/design explorer to .svg vector based icons.
Which version of Alibre are you using?
I'm on v23.
I'm using Pro. I'll get back on maintenance if I ever use Alibre long enough to justify the price. The price is quite reasonable, all things considered, but I'm strictly a hobby user and often end up using 'pencil CAD' because I'm not very fast in Alibre. I'm trying to change that, but my time is very divided.The beta testing version of V26 dropped yesterday evening. I'm using Alibre Design Expert version with active maintenance, so was able to get it for testing.
Loving it so far. The new .svg based user interface looks pretty slick in dark mode. The 2d drawing workspace has even more changes. The dimensioning seems alot better:
