- Jan 5, 2014
- 944
If you do want to measure current and have a volt meter but not an ammeter, you can put a resistor in series with one lead and measure the voltage across it.
A 1 Ohm resistor at 3 amps would measure 3 Volts for example (And warm up pretty good due to the 9 Watts.)
A 0.1 Ohm resistor at 3 amps would measure 0.3V and only need to dissipate 0.9 Watts.,
Etc.
A resistor maybe rated double the power you need is a good plan.
Current = Voltage / Resistance.
Power = Voltage^2 / Resistance or Current^2 * Resistance
Etc.
