- Feb 20, 2019
- 335
There is often times a clutch on the feed mechanism, not going to be a very good thread when your clutch slips.
By vertical CNC lathe, I mean put the work on the spindle and mount the cutting tools on the lathe to turn a part. I had designed a tool post for my mill (yet to be built as I haven't needed it) that will mount cutting tools using the old OEM 4 way tool post from my lathe.Thanks folks, Good comments and appreciated. I'll respond to them a bit below.
Hi Jim, Yes, I once saw a U-Tube video where some one had done this. It looked cool. But then I lost the link so have to search for it again. Sometime.
Yes, 7mileup. You would want to leave it engaged. The reason for doing it might be that one could get TPI values which are not available other wise. On my PM1440GT, and including the change gears that come with it that amounts to about 1500 additional TPI values (It is possible there are some redundancies.). Without the change gears there are 16 possible feeds and so TPI additional values.
Hi Christian,
I am not for sure what the effect of the different kinds of teeth on the lathe bed would have. Anyway, if you keep the feed lever engaged, back out the tool a bit, and backed up the apron, put the tool back to a cutting position, and go again... I would think the results would be repeatable. This is what some folks advocate when using the proximity stop approach. However, maybe the Feed threads are not always uniform? I would think that the fact that the 1/2 nut grips multiple lead screw threads that it tends to reduce backlash and cutting resistance, as well as other possible clamping issues. I am not an expert on threading, but sometime I will try this out and just see if it is repeatable. On my old South Bend where I need to replace the 1/2 nut along with a bunch of other rebuilding, I can hardly cut a thread anyway. (The lead screw on it seems to be in very good condition.)
Hi CWilliam,
Cool, so there is sometimes a need for rather unique TPI values.
Using the spread sheet tool that I have been working on I find that there are several external gear setting where I can get 3.3333 or 3.33?? threads. ??=> other digits. But you cannot get either of those with the 60/30 external gears that are normally used on the PM1440GT. The tool is nice as it generates all possible TPI values for all possible gear settings as well as all possible external gears that I possess into a table. Then I have a macro command that will search for almost anything you request for in the way of TPI. It appears that there are 5 possible unique gear and lever combinations out of the 6144 possible combinations of gears and settings to get the 3.33?? values. The PM1440GT has 16 fundamental TPIs that can be reached with the main gear box, then it can generate times 4 possible factors of 2 of these. So that yields 64 possible threads without changing an external gear. Suppose you have inserted external gears, like 65T/30T, 69T/28T, 60T/28T, 60T/35T, or 60T/42T which are not the more common 60T/30T gears of the 1440 where you would cut a 24TPI .... and you wanted to cut it without taking the cover off and removing gears. Would it not be nice to just change the gear box levers and get the standard thread? What gear settings do you use? Just search for 3.33?? in the tool and you find either 24.000 or 24.00?? for each of the external gears I just mentioned. The Power Feed values just make more entries to that search. The PM1330GT manual says that you cannot get to the 13.0000 TPI with the standard 60T/30T external gears. However, I have found that there are 60T/28T, 60T/30T, 60T/35T, and 60T/42T combinations will get the exact 13.0000 TPI value. If you are willing to drop the preciseness to 13.0??? then I find 9 unique settings. Even the standard 60T/30T yields 13.0909 TPI which is with in 1%. Maybe the manual should have said that, but maybe the author did not know?
Yes, I prefer to use my lathe by hand too, but I do find that if I want a really smooth surface the power feed does a better job of making the cuts uniform. This seems to be especially true on soft materials like brass. My CNC mill has enough backlash that the circle cuts are not really round! Also the final surface always has cutter marks. The nice think about that CNC lathe video was that you could effectively turn the CNC off and it worked like a manual lathe.
Dave L.
It would just crash a tool into the spindle if it were not for my proximity sensor system. I suppose with the proximity sensor in place one could get rid of the Feed shaft clutch or redesign it. One might ask, "Does one need a safety clutch on the slow feed mechanism why is there not one on the lead-screw as well?" Maybe just for this reason!
Dave L.
VFD conversion using solid state electronic components.
Thank you for your response! It is very through, useful and very informative. Base upon the input from the forum, an especially your experience, I have decided I will include the possible threads one can get from the FEED position in my over all charts. It seems clear that some folks have lathes which can be used for this and their operators are sufficiently skilled to make use of the information. Others may not need it or be sufficiently skilled to use it. My spread sheet tool will also be constructed so that if one does not want the FEED thread info they can always leave the data out of the search or the overall threading table.There are several methods for threading vs carriage travel.
