- Dec 25, 2011
- 10,513
Are you saying that the keyway in the gear is 1/8" wide and 1/8" deep? If that is the case and if the keyway in the lead screw is 1/8" wide by 1/16" deep, then the mating key will need to be 1/8" x 3/16".
I think he means the other way around.
He dropped a 1/8 x 1/8 keyway into the Lead Screw Slot and it went to the bottom with nothing showing.
