    Dismiss Notice
Possibly Buying A Ko Lee Grinder
Discussion in 'K.O. LEE GRINDERS' started by cs900, Sep 26, 2016.
  1. cs900
    cs900 United States maker of chips Active Member
    148
    43
    City:
    binghamton
    State:
    New York
    -Return to Top-
    So pretty empty in this section of the forum, haha. hopefully someone will chime in. I have the opportunity to buy a KO Lee grinder locally, but really don't know a whole lot about them. Combine that with the fact that this would be my first surface grinder, and I could defiantly use some direction. The grinder looks to be in fairly good condition, although it does look like some of the hydraulics might have a slight leak. Any other issues I should be looking for? Parts hard to find? Looks like leblond took them over, but i haven't found a good source to confirm part availability.
  2. rgray
    rgray Active User H-M Supporter-Premium
    282
    83
    City:
    Helena
    State:
    Montana
    -Return to Top-
    I have one that looks a little like that. Mine has hyd cross feed as well. I haven't used it much but it seems to grind real nice.
    I also have a K O Lee tool post grinder and it has those same kinda controls. The controls and dials are not very nice compared to most. A DRO would be real nice on one of those to increase your "sensitivity/knowledge" of "what/how much" vertical movement happened when adjusting the wheel down.
    Only thing I have to compare it to is a Jones & Shippman 540 and a #5 Brown and Sharpe (cylindrical) Both have much better wheels and dials than the K.O. Lee.
  3. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    1,905
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    I have both a Brown & Sharpe 612 surface grinder and a K O Lee tool & cutter grinder. Both are nice grinders. I would say the B & S is a nicer surface grinder than the KO Lee in ways. I'm sure the KO Lee will do good too. One nice thing about the KO Lee, it has roller bearings that the table rolls on that stay lubricated with oil, provided it has been taken care of. As for the hydraulics, well its like all other hydraulic systems I've dealt with over the years, they leak oil over time. May require replacing seals/O-Rings, etc. to get the oil leaks fixed. Depending on price and condition and how much TLC you have to put into it up front, it will make you nice surface grinder. Ken
    EDIT: As for repair parts, plan on making your own. If you go to Leblond for parts, take your heart attack medicine with you, you will need it!
    The tool & cutter grinder I have, I had to make a new cross feed screw and replace a couple of oil seals and that about it. The super precision bearings used in the spindle are off the shelf bearings, just expensive! I've managed to snag a couple sets off of eBay for under half price of new one's.
  4. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,208
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    What size is the grinder? 6x18", or smaller? Hard to tell, the wheel guard looks big in comparison to the table chuck mounting area. Does it come with a mag chuck? If not, that can be a big dollar purchase, figure it into the price you pay for the grinder.
    4gsr likes this.
  5. Holescreek
    Holescreek Active User Active Member
    456
    63
    City:
    Centerville
    State:
    Ohio
    -Return to Top-
    I have a KO Lee S618, manual machine. Thing to watch out for: On my machine there are 6 "wells" under the table (they are cast in the top of the base) that should be filled with way oil. Three in front and three in back. At the top of each well there is a pair of rollers sitting on top of a strip of spring steel. The purpose of the rollers is to distribute way oil from the well onto the bottom of the table. When I got my machine several of the rollers were broken off and several of the spring strips had snapped too. I made my own springs from spring steel strap and the rollers from whatever I had laying around. I probably have photos on my home computer if needed.
    I also had to replace my spindle bearings. There again, if the spindle is the same between the models there was a trick I stumble upon when I replaced mine. It's been so many years ago that I forgot I even did the job until I was sent a PM from someone on another board asking questions. I had to go back and read my original thread to refresh my memory.
    4gsr likes this.
  6. Holescreek
    456
    63
    City:
    Centerville
    State:
    Ohio
    -Return to Top-
    pics:
    edit: Just seeing that grinder naked and alone about 14 years ago made me sad so I added a newer one showing it in a more current setting.
    Bob Korves and 4gsr like this.
  7. Andre
    Andre Active User Active Member
    576
    113
    City:
    NY
    State:
    New York
    -Return to Top-
    Yes, that looks to be a 618 size grinder. (At least in the picture, to me.) Great size for sharpening planer blades! My 612 is just a tad too short :(
    Sent from my XT1053 using Tapatalk
  8. cs900
    148
    43
    City:
    binghamton
    State:
    New York
    -Return to Top-
    thanks for the reply guys. I'm still working with the guy to make the deal. I'm also in the middle of a full home renovation so time is the limitation.
    I believe it is a 618 as well, and it does NOT come with a mag chuck (one of my bargaining chips :p)
  9. rwm
    rwm Active User H-M Supporter-Premium
    1,035
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    He looks happy now with all his friends....
    R
  10. ranch23
    ranch23 United States Active User Active Member
    7
    18
    City:
    Glenrock
    State:
    Wyoming
    -Return to Top-
    Well fill us in please.
  11. Holescreek
    456
    63
    City:
    Centerville
    State:
    Ohio
    -Return to Top-
    I just googled "k.o. lee spindle bearing holescreek" and found the thread from 2008. Gotta love the internet.
    rgray likes this.
  12. ranch23
    7
    18
    City:
    Glenrock
    State:
    Wyoming
    -Return to Top-
    Thank You, I have a K O Lee B602. What a nice machine, I use it primarily to grind actions.
Share This Page
