TC,
If by "originally" he means "from the factory", I could give you the list, but from memory:
6" Faceplate
One Lathe Dog (don't remember which size)
2MT Dead Center (2)
2MT to 3MT Sleeve
Lantern Tool Post with Rocker and Rocker Sleeve
Wrench for Tool Post and Carriage Lock bolts
Maybe one or two other minor pieces
3/8" Square HSS Tool Blank (unground)
Current Edition of the MOLO
Otherwise it could be anything from soup to nuts.
On the bench, look at a catalog photo of the cast iron legs with built up hardwood top and shelf. That's can be taken as the minimum that will give satisfactory performance. All other things being equal, there is some rigidity benefit to having the leg pairs closer together at the top than at the bottom. The original stand for the TV48 weighed 160 pounds. Unfortunately, none of the catalogs seem to give the dimensions of the top. Atlas for a few years also offered a hardwood 2-drawer cabinet. It's top dimensions for the 48" and 54" bed lathes are 14" x 57". And it would mount either vertical or horizontal countershaft lathes (TVnn or THnn).
Robert D.
Robert D.
6" Faceplate
2MT Dead Center (2)
2MT to 3MT Sleeve
Robert D.
Robert D.
