Poor Man Dividing
jocat54
H-M Supporter-Premium Member
Dec 25, 2011
467
Likes
258
#1
Using a cheap rotary index and some 1/4" x 5 1/2" acrylic discs. Drilled the holes using the DRO bolt circle function. Made 5 discs using numbers not possible with the original rotary index, up to 48. May make more if needed--they are pretty easy to make
Whyemier
Jul 11, 2014
473
Likes
372
#5
Actually was wondering if something like that was possible and how to implement it. Thank you!:aok:
Hukshawn
H-M Supporter - Premium Member
Nov 19, 2016
755
Likes
474
#7
What is the "dro bolt circle hole function"?
jocat54
Dec 25, 2011
467
Likes
258
#8
It is a function of some?(most)? DRO's that will give the coordinates of the xy axis to drill holes for a given diameter.
You enter your center of a cirlce x-0/y-0 and the diameter of the circle you want, the number of holes, the start and end angles.
Edit: Also known as Pitch circle diameter--probably the correct name.
larry4406
Active Member
Active Member
Dec 19, 2016
37
Likes
8
#10
I am a newbie reading a lot.
I've seen the threads on using saw blades and counting teeth.
Anyone ever used a cross drilled brake rotor? Not sure the patterns used for drilling.
Container Above bottom breadcrumb
