- Oct 13, 2014
- 6,973
Made in Germany.The 150 has a 3/16" orbit, but Jesus Murphey, it's $825... Why are these sanders so expensive?! Someone just put an electric motor in a pneumatic sander... Why is that so complicated?? Lol
And my only other compressor is a little 12gal I use for work when framing. At one point I considered getting a pig tank and stowing it somewhere along the line to double my volume. The pump would run longer but get a longer rest. And then eventually upgrade the pump. But the idea of adding a second potentially explosive pressure vessel to the house just didn't seem smart. Haha.
Even the small compressor will help. Just be sure to put a check valves on the outputs so the air from one compressor can't back back into the other. You can make a simple manifold from a tee fitting.
