PM932M PDF Quill Handle
richz
Jan 19, 2012
177
When the quill handle is up the lower handle is facing forward sometimes getting in the way. Is there any way to somehow swap it around or reverse its position with the handle on top. Also I lost the manual that came with the machine (though it was not very good). Would anyone have a copy?
Do they not un-screw from the hub? In the pics it looks like they have a spanner flat at the base.
I have 3 handles on my rongFu mill but generaly only one installed, I move it between holes in the hub depending upon throw of current drill bit or take them off completely if milling very close to the table. I only ever hand tighten them in.
Stuart
It's been a while since I removed my handle but moving it's position may affect the PDF (amount of travel). I forget as I really didn't pay that much attention to it when I needed to remove it years ago. Really easy to work it around it when it does get in the way.
