- Jun 12, 2014
- 4,816
A 19mm shaft is typical of a IEC 80 metric motor frame which would be 1 Hp. The 1.5 and 2.0 Hp metric motors have 90 metric motor frames with 24 mm shafts. Marathon Electric does make a 1.5Hp metric motor with a 19mm shaft, but only for their 3600 RPM motors which has an IEC 80 motor frame. http://www.electricmotorwholesale.com/MARATHON-R395.html
It would be possible to machine/turn an adapter shaft/coupler with a motor riser, but probably more trouble than it is worth unless you cannot find a 3 phase motor. Another alternative would be to use a BLDC or AC servo motor with controller instead of a VFD. I had this one on my last mill and they pack a lot of Hp/kW into a small motor package. The NEMA 42 looks to have a 19mm shaft, but would still need an adapter plate.
https://www.aliexpress.com/item/AC-...M-110ST-AC-Servo-Motor-110ST/32356188922.html
DMM is in the US and also sells AC servo drives at reasonable costs, may be worth checking into. They have a 1kW model with a 19 mm shaft, 11A-DST-A6HK1
http://www.dmm-tech.com/ac_servomotor_main_a1.html
