- Jun 12, 2014
- 4,811
Hopefully the final iteration on this similar to what Alan H. did except soldering in the segments. Use 0.5" brass rod and through bore with a 0.25" drill, can either drill from both sides and cap one end or I sequentially drilled from one end to a depth of 8.25" in a 8.5" overall length brass rod using aircraft drills. I drilled one end with an 11/32" drill to 1" and tapped with a 1/8" NPT tap for the brass elbow. Feeder lines are 1/8" copper tubing, I suggest using the softer thicker wall copper which is easier to bend, although I used the 122 copper. Cut segments with a wire stripper <> cutters, may need to lightly file the ends and use a small awl or center punch in the opening. I used a SN-AG-CU solder with a blow torch on its lowest setting to solder the segments in. Pretty straight forward to make and didn't take too long.
Formable Easy-to-Machine 353 Brass Rods
Copper tubing 1/8" 3' or 6'
3' Super-Conductive 101 Copper 0.032" Thick Tube Wall, 1/8" OD which bends easier, similar to 4 mm Bijur tubing
OR
Weldable 122 Copper Tube 0.014" Wall Thickness, 6 Feet Long, 1/8" OD which is stiffer but can be bent
Elbow if going to 4mm tubing:
PPST30 24" High Pressure Flexible Hose (600mm) for Lubrication System 4mm Bijur
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
www.mcmaster.com
McMaster-Carr
www.mcmaster.com
McMaster-Carr
www.mcmaster.com
Fitting Pipe NPT 1/8" Male X Compression 4 mm OD Tube Tubing 90 Deg Elbow | eBay
Fitting Pipe NPT 1/8" Male to Compression 4 mm OD Tube 90 Deg Elbow Brass. End A: Pipe NPT 1/8" Male. 90 Degree Elbow.
www.ebay.com
PPST30 24" High Pressure Flexible Hose (600mm) for Lubrication System 4mm Bijur | eBay
Max Pressure: 150kg/cm². Orders under 150 lbs. Orders above 150 lbs. Fullerton Office. Piscataway, NJ 08854.
www.ebay.com
