- Jun 12, 2014
- 4,817
Hi Dan,
Pulley is outside diameter, but there is a wide range. This pulley by TB Woods BK2834 is a 3/4" bore, 2.95" outer diameter and B size belt that should work with the stock motor. It should work with a BX25 belt length. The stock motor pulley is 2.2"OD and 3.5"OD. I use a 2.6" pulley (7/8" bore) on my machine, but I have the inverter motor set for 120Hz on the top end.
TB Woods BK2834 pulley cost is $11.26. https://www.amazon.com/TB-Woods-BK2834-Bored-Section/dp/B003N17PQA
Mark
Mark
