Why did they add the PM 932M? I don't see much of a difference from it to the PM45M?
Am I missing something? Biggest advantage I see is that the 932 has 5" of quill travel.
Probabably for the same reason Grizzly added the G0750G over the G4003G lathe. Not many differences but it's available from the CM & better for Matt to offer more options.
Really, I don't see that much of a difference as far as the base machine. Not sure if the specs are accurate as the PM932M is listed as having an ever so slightly smaller table & X-travel as well as a smaller dia quill over the PM45M. I really speculated both mills as being the same exact base unit (based off the RF-45). Just the PM45M comes standard with coolant & has variable speed option & that the PM932M comes standard with X & Z power feeds along with the cast iron base but no coolant (unless I missed that somewhere).
If the PM932M was available at the time, I would have chose that over the PM45M as the coolant & variable speed option are not important to me but then again I have no regrets getting the PM45M.
I don't see the quill travel as an advantage/difference though. The PM45M is listed as having a 4-3/4" travel but my PM45M has just over 5" of travel. I'm not sure if that's because I have the PDF model though.
Do you guys give up rigidity with the PM45M compared to a full size Bridgeport clone?
Do you ever need more Y travel? 8" does not seem like much.
Probably so. It's been a while since I've had machine time on real BPs but it was not a lot. I do remember BPs being more rigid but again I can't really make that good of a comparison as it has been a while. But they are two totally different animals though which are not in the same type of class. I would like to have more Y travel though. I ran out of Y travel & learned that a 5" vise can not be used to it's full capacity on this mill. But more Y means entering the realm of a full size knee mill.
Here's my Y maxed out & that's with the Z axis chip guard unmounted & lifted up for more clearance as it hits the vise. I probably could have gained sufficient travel if I removed the Y axis/base chip guard & unmounted the X axis DRO scale but I wasn't about to do all that & found a different solution to make the cut.
PM45M PDF is $2600, + $300 X power feed, + $750 DRO = $3650
I would hate to spend that much money and regret not getting the 9x35
That PM935T sure does look nice though. If that was available at the time, I would have done my best to try & get that! I was drooling over a
Modern 935VS-1 at the time which the PM935T looks to be the same type of beast. But that's considerably more & not sure I could get that setup in my garage. That's borderline too much machine for me. Maybe one day.
