- Nov 27, 2012
- 7,855
The tool offsets are programmed just like the SDM function found on most DROs. In the manual I uploaded look for the SDM instructions. For lathe specific DRO displays it's not usually specifically labelled as SDM but as Tool Offsets instead.Yes, that looks almost identical other than the addition of the key between the Offset and R/D keys on mine.
When mine boots up it shows "Top10-2L", so they are likely both Meister brand.
Thanks for the link, however the manual that you linked to answers some questions but still falls short of what I'm looking for. I suspect that somewhere there is a manual specifically for model, it's just finding it.
The reason I choose the DRO display I got is because it was lathe specific & the SDM/Tool Offsets is more easily accessible than other universal/mill DRO displays.
That additional button on yours looks like it's axis summing but that's usually found on 3 or more axis DROs. For a lathe, axis summing would commonly be for the carriage & tailstock (or compound slide if the user choose), need a scale mounted on both. I'm curious if that button even does anything on your DRO if it's only a 2 axis.
