- Dec 3, 2013
- 1,844
Have you seen this thread? http://www.hobby-machinist.com/threads/pm-727m-powered-z-axis.45294/
To use a power feed like on the PM-833 you would first have to determine if the stub shaft for the crank on the PM-727 is long enough and has a diameter that can adapt the power unit and bevel gear and you would need to come up with a way to bolt the power feed to the mill. This manual shows how they typically install. http://www.shars.com/media/manuals/user_manual_XYZ_shars.pdf
The PM-932 & PM-940 use a gear motor coupled directly to the Z axis lead screw on the top of the column.
I re-purposed the gear motor off my PM-932 to raise and lower the table on my heavy duty drill press. http://www.hobby-machinist.com/threads/something-a-little-different.55567/#post-463941
Any of these methods will require some modification and fabrication of parts.
