Agreed, I pitched all my Chineseium. The T-15 is Vasco Supreme - VERY hard to grind but I have found a very good routine: 36 grit ceramic belts, then CBN wheels. Plus my shop made tool rest for the grinder helps big time.At home (as opposed to school), I have only ever used cheap import HSS tool bits. It does the job for a while, & then requires resharpening sooner than I would like.
At the one school I went to, they used the good stuff. I never saw a tool bit require a trip to the grinder.
I should change to quality HSS tool bits.
