- Jan 2, 2019
- 6,574
Three phase is readily obtained from a static or rotary phase converter, I have this one
on the back of my lathe and it does the job fine. If I want a VFD later I'll do the mods but my machine has a long way to go before then. Definitely order the three phase machine over a single phase one since you will have to replace the motor if you want to change over later.
I can't speak directly to PM machines or accessories other than to say folks around here speak highly of them and willingness to sponsor/participate in our forum is a big plus in my book.
If I were doing it I would get the DRO installed and worry about other stuff later unless there was a special deal to be had. A keyed drill chuck will work the same as keyless for most operations but getting the 4 jaw with the machine makes sense. If you want to start working right away just order a phase converter and you should be able to hook it up and go.
John
SPC-3
Run motors at two-thirds power with the heavy duty SPC-3 Static Phase Converter. This static phase converter offers reliable performance for any industry.
www.northamericaphaseconverters.com
John
