- Mar 23, 2022
- 25
Received the lathe and got it set up. One thing I didn't realize is that the bottom area of the chip pan is elevated from the edges. I put some 3/4" boards under the chip pan so the lathe would be on solid ground. For my first project I decided to make a spider. The spindle doesn't have any extra material for a screw on type spider, so I built a slide in spider. Inside diameter is 1 1/16", which I can probably make it a little larger if needed. I turned it down slightly under the inside diameter of the spindle bore and added some O-ring grooves for a tight fit. Worked out really well. I used #84 O-rings. I have some 2 1/4" brass bar stock I used to make the spider. Picked up some brass screws and nuts as well.
