- Mar 3, 2013
- 1,448
Yes, I am positive that I need a motor rated at 3600 RPM or thereabouts. The lathe is a vintage precision bench lathe that was originally designed to run at a maximum of 3500 RPM. The lathe spindle runs a pair of size-matched V-belts which pass through a hole in the bench straight down under a headstock cover. I just found out that my friend who is selling the lathe to me will supply the SAME SIZE pulleys for mounting onto the motor shaft, so the drive ratio will be 1:1.
So far I now know that I want a 230/460 VAC motor, 1hp - 1.5hp, 3600 RPM (+/- a few RPM's) and (for reasons I don't understand) I don't want sleeve bearings.
Why are sleeve bearings not desireable?
I have yet to pick a VFD - thanks for suggesting dealerselectric.com.
...Doug
But didn't that machine lathe have belt reduction to give a wide range of speed? (See link below). It says 150-3500 rpm. You will NOT get near that range with only a VFD for speed control. You are limited with a VFD at the low speed end by two things. #1 Motor cooling, the motor must run at a speed fast enough for the internal fan to cool it. #2 Power, at slow speed. You can go to a more powerful motor to help #2 but there isn't much you can do about #1. Personally I don't run any of my VFD driven motors below about 1/2 rated speed and no more than 1.5x rated speed. Using those seat of the pants numbers and a 1:1 belt ration with an 1800 rpm number you could go from 900 - 2700 rpm. Using a 3600 rpm and 1:1 it would be 1800-5400 rpm. With a different belt ratio you can move this speed range around but you will always have a limited range unless you provide for a way to change the belt ratio. I also like slower motors because are quieter and run smoother.
FWIW my Logan has it's original 1945 1800 rpm sleeve bearing 3 phase motor, I did put new bearings in it when I got it.
http://www.lathes.co.uk/rivett/page7.html
