I just received a new PM-30MV mill for a CNC conversion. There are a few things I haven't seen talked about very much in the forums.
1) How do you disable the quill? Do you remove the course and fine gears and all the other quill components? How do you lock the quill from moving?
2) Why don't CNC controllers use the DRO installed on mills?
3) Does it matter which side of the X-axis the stepper is installed on? It seems that most people mount it on the left side.
Thanks for any insight into these burning questions.
Mark
Mark
