- Nov 25, 2015
- 8,338
yea, I wish. You can't easily get them in a basement... you can get them in.. just not easily, and they are not coming out with out a crew even empty.
I have them installed on my small one at work , but it never gets moved Mike . Someone stated above the depth was too much . I will say , these are made more on the lines of mechanics boxes . Machinist tools aren't that heavy . Weight till he loads it up ! ( No pun intended )I would put some really heavy duty casters on those things. You will need to move them and you will load them up. Casters will make them manageable.
he doesn't need it, he just picked up a pallet jack. He only needs to be able to get under them.... a better solution.. one jack, many options.I would put some really heavy duty casters on those things. You will need to move them and you will load them up. Casters will make them manageable.
I think Mike meant for turning into a roll around box .he doesn't need it, he just picked up a pallet jack. He only needs to be able to get under them.... a better solution.. one jack, many options.
A forklift is the answer, but I don't have one. I was quite disappointed the pallet jack won't fit into rails because of the wheels. I was able to use it by tilting and sliding it onto the top of the forks. It's not ideal, but it worked, and my options are limited. These boxes will reside next to each other against a wall, and won't move until I do after retirement. I plan to put a top across them, and I should be good to go - until the next timeI've moved mine at least three times, easiest was when I had the forklift. Depth isn't a problem if you have a bench that's the same.
JOhn
it looked like you had a narrow pallet jack.A forklift is the answer, but I don't have one. I was quite disappointed the pallet jack won't fit into rails because of the wheels. I was able to use it by tilting and sliding it onto the top of the forks. It's not ideal, but it worked, and my options are limited. These boxes will reside next to each other against a wall, and won't move until I do after retirement. I plan to put a top across them, and I should be good to go - until the next time
The forks lineup and would fit just fine, but the thickness of the front wheels inside the forks is the deal-breaker. The wheel assembly is taller than the rail opening.it looked like you had a narrow pallet jack.
They wouldn't fit between the rails?
Did they match the existing rails? I have an idea...
