- Sep 1, 2023
- 489
Yeah, I read that and as I said above, I wasn't even aware that plus and minus sets were a thing! I didn't know you could choose the direction of the tolerance!7um over nominal (about 0.0003”) in the worst case doesn’t seem that terrible. Clearly this is a plus set (all measured values were at or over nominal).
For the record, I generally machine to the closest thou (I have much less metric tooling). But working to the closest thou means I need gauges and standards that are held to tighter tolerances.
For the reason most concisely expressed in comment #42, I prefer minus toleranced pins for gauging a hole (“measuring” is common parlance but even micrometer measurements are relative to standards).
I'll probably look to get a 0.5 - 5mm minus set from a supplier that shows the tolerances explicitly (so, not AliExpress) at some point.
