- Jan 7, 2016
- 3,273
I used 14 gauge steel to make a chip tray. Made a template for cutting the corners (which still wasn't quite right) and used an angle grinder and cutoff wheel to make those cuts. I also scored along my bend line because the brake that I was using was rated for up to 16 gauge, and this 14 gauge was going to need some serious gronk to get it to bend. I decided to make my life a tad easier with the score line.
I also welded some short pieces of tubing around the mounting holes to make it drip proof. I plan on using a mister vs flood cooling, but I still wanted to make sure that any liquid would not leak out around the mounting bolts (which are 1/2 dia BTW) and ruin my cabinet underneath.
