A
Andre
Forum Guest
Register Today
Why would you need to disengage the worm? Or is this an assembly/maintenance thing?
The thread is called "rotary table problem" started on 6-18-12 by video_man. I'm in my iPhone and found it with Google.
http://www.hobby-machinist.com/showthread.php/7241-Rotary-table-problem?highlight=Rotary+table
Andre, you disengage the worm to be able to rapidly position the table by spinning it by hand.. These tables are usually a 90:1 ratio so it takes 90 turns of the handle to rotate the table 360 degrees...a lot of crankin if you just want to turn the table to a known position.
Darrell
Good thinking, Shadowdog500, thanks!
