- Mar 7, 2018
- 105
The mill is a Clausing Kondia
Motor data:
my phase converter:
my magnetic switch:
inside the switch:
Installed new belt. Motor spins freely with no binding. When I power the mill up it will run for about a minute then trip a 20 amp breaker. When connected to 30 amp breaker, the magnetic switch trips. The exterior of the motor is warm but I don't know what the temp should be. Before I changed the belt and installed the magnetic switch the mill ran fine on the 20 amp breaker.
Question one: Using a multimeter, how should I check the wiring? And what values should I be looking for?
Question two: I cannot find instructions on the magnetic switch geared to someone without knowledge (me). Is there an adjustment inside the switch I should make?
If it gets too complicated for me I will look for a qualified person for help. I do know my limitations. Sometimes
Motor data:
my phase converter:
my magnetic switch:
inside the switch:
