- Jan 28, 2022
- 845
Martin, thanks very much.Nice work! Looks great
Martin
Hello and thanks for the reply. Yes I did make it using 2"x2"x.120 . Everything is mounted with isolators. In the vertical position the wheels are off the ground. The red run light is for when weather permitting I can put it outside for peace and quiet. Thanks again. Charlie. Nice truckThat's very nice. Did you make the stand?
Regards
No, it's a 208-220-440 wired 220 motor, not a 3 phase motor. Thanks.I know how the rotary phase converters work, employing a 3 phase motor. How do you set it up with a single phase motor?
Thanks - from one Chevy guy to another.Hello and thanks for the reply. Yes I did make it using 2"x2"x.120 rec. Everything is mounted with isolators. In the vertical position the wheels are off the ground. The red run light is for when weather permitting I can put it outside for peace and quiet. Thanks again. Charlie. Nice truck
