- Nov 23, 2014
- 2,609
I agree with epanzella, you can't have too rigid of a set up for parting. I had problems on an Atlas 12 x 36 and a Rockwell 10 x 36 using latern style tool holders. I made a tool holder block for a piece of 5/8" x 1/8" HSS cut off blade. Mounted the steel block to the compound with a bolt/T-nut. Marked the center line of the lathe on the block with a chucked up scribe. Milled the slot for the blade, drilled/tapped a couple of holes to lock the blade. Went from pecking away to getting through 1 1/2" rounds of steel with no issues. Tom's Techniques has some good info at his web site. He always sharpens the HSS blade before cutting.
Bruce
Bruce
