- Sep 26, 2013
- 13
I'm new to using a parting blade and I'm clearly doing something wrong but I don't know what. I've got the blade extended just a bit more than the radius of my part. I feed slow (it's a 6" lathe with a broken crank so I can't go that fast). I'm perfectly square with my QCTP to my chuck. I drizzle cutting fluid on the cut as I'm going. And yet, I get a little bit in and the bottom of my parting blade snaps off. What am I doing wrong?
Incidentally, I'm trying to part a 1/2" steel rod with the brand new (now trashed) P1N parting tool from Shars. Snapped it one way, flipped it around, re-checked everything, fed it in and snapped the other side. Ugh... As you can see from the photo, it's just the very thin bottom part of the tool that snaps off.
