- Oct 16, 2019
- 6,580
The drive belt setup looks like this: (this is not my lathe but same setup)In what way does the belt pop off? My machine stalls, and I have to back off or hit the e-stop.
Is that at all alarming for you with the belt pops off? I am no longer alarmed because the machine has always started back up again for me. I imagine that my belt is slipping on the pulleys when it is stalling; if this is not the case, then a lot of heat would be generated in the motor while it is stalling, as I understand it.
So how long would it take you to part a 2” diameter mild steel round bar? How many times would you bury the parting blade into the work during this process?
What happens is the belt slips off the spindle pulley. In the picture it would move to the left. It's a complete non-event. I just turn off the lathe, release the tension lever so I can reinstall the belt and away I go.
I have parted 1.25" 1018 steel in about 15'ish minutes. I cannot imagine it taking an hour. One thing to note is that I don't use the power cross slide when I part.
